1988 90 misfire (tips on replace plugs/wires/distributor)
Hey guys! Im new to this forum and to audi all together. I have done a lot of work on older chevys but this audi was too good to pass up. The car has been misfiring very badly, at idle the engine is shaking and u hear the misfire, and the car is definitely not running at full power. I figure i would replace the spark plugs, wires, and the distributor. I have heard the distributors on these older 5 cylinders can be a pain the *** to get out. Also upon looking at the spark plugs it appears the wires don't just pull off the plug, there is some sort of clip or something i am unfamiliar with. Anybody have any insight or tips on some stuff maybe i won't know going into it????
any advice would be greatly appreciated
Thanks!!!!!
Thanks!!!!!
To remove the stuck plug wire (end on plug), use the special screw driver (bend 90 degree on end of screw driver)
and (or) use the puller etc. Before replace the all parts, check the compression and should have more than 120psi and you will have starting problem if your engine has lower than 120psi.
Misfire problem on your engine probably plug wire end on plug( register has open ) or low compression in cylinder. Wire itself is OK most of time and check the connector on distributor side and rotor (burned resistor? ) . x19
Hey thanks!...i was able to get them off..I changed the plugs and it didn't make any difference i bought a knew distributor cap and rotor..and im just waiting for the wire set to come in the mail. Hopefully this will fix the misfire issue. I did a compression test when i changed the plugs was running 150-155 psi on all 5 cylinders so the compression is good.
Thanks!
Thanks!
Mark VII
14
09-26-2023 10:11 AM
Alexandroff
11-21-2017 01:45 PM
anticsAK
09-04-2015 09:59 PM
stormchaser1967
09-02-2015 12:47 PM
