bad fuel pump?
bad fuel pump?
Hey all decided to get myself a 1990 audi 200 two days ago with an mc2 engine, has been running fine all weekend, though every start was rough and needed 4-5 seconds of cranking. Yesterday i went to start the car and nothing it just cranks over and over. I took inlet to fuel filter off and tried cranking again and nothing is coming out, fuse for fp is good and i can not hear the pump whining when the ignition is turned on, could it be a bad pump???
No start?
Try to jiggle the electric wiring on Coolant temperature sensor or sensor itself weaken or dead?
Also. you have to use the fuel pump pressure gauge for determined good or bad F/pump. Good luck. x19
brad131a4
03-03-2013 03:49 AM
