Exhaust manifold/header options for MC 10v turbo...
#12
I don't know who anyone is yet, I guess I'm just too new around here. What are their forum names?
Cheers,
Colin
Cheers,
Colin
#13
Myke is known as Toxcheap and Den is famous for the car name ... evilwagon. like i said, i don't believe Den gets on. check out their site @ www.toxcheap.com
#14
Does anyone know if the summit racing 8mm nuts are copper?
Eagle day has copper nuts for less. ( 4 for 2 dollars)
The plated internal hex bolt kit they sell has been invaluable. With the washer kit and some of std. hex head bolt kits its pretty everything you need.<ul><li><a href="http://shop.store.yahoo.com/eagleday/sohebo.html">http://shop.store.yahoo.com/eagleday/sohebo.html</a</li></ul>
#15
And they are multi layered... like 4 layers...vs the mc's 1 layer... Is this making for a thicker HG? Yea i knwo what you mean James about those hex nuts......
Hank
Hank
#16
I'm not sure about a 10V gasket.
The KW was a thick 1 layer fiber piece with metal rings around the piston openings. The UrS4 gasket looked like a superior product and was about the same thickness at the KW.
#18
I'm not going to look to see if I saved it either, as I don't want to step on any toes.
Myke will let some of the secrets go, but I also know that he's the type of person who thinks that "hey, I/we spent the time and money to figure it out, so should you, or at least attempt it and put some thought into it first". I'm sorta the same way.
#20
Is better than any CIS modified to the brim(correct me if I'm wrong)
But then again the tricks Myke and Den used had to be a lot cheaper than switcing to EFI. Thats the whole plan, speed on the cheap!
