What's the difference between a 3B & AAN engine?
Allows for overboost in short durations and also uses distributor-less ignition (aka coil pack).
The overboost feature, coil pack, and updated code allows for an extra 11hp (217hp vs 228hp) and 30lb-ft more torque (228lb-ft vs 258lb-ft). I believe the torque curve is also flatter due to the changes. Numbers are from memory, but should be close.
elmago
06-25-2007 12:40 PM
