CEL came on and these are the codes i just got...why would so many
cylinders be misfiring....
16684
Random/ Multiple Misfire
16685
Cylinder 1 Misfire
16690
Cylinder 6 Misfire
16689
Cylinder 5 Misfire
16688
Cylinder 4 Misfire
where should i start??
16684
16685
Cylinder 1 Misfire
16690
Cylinder 6 Misfire
16689
Cylinder 5 Misfire
16688
Cylinder 4 Misfire
Sounds like it's one bank of cylinders mostly, probably #4 since it's the closest to the radiator and gets more heat. I'd replace that first, then re-VAG to see if you're still misfiring.
I had that exact problem on my car back in August. Cylinder #4 was misfiring, and #5 and #6 were also misfiring. I ended up replacing all six coil packs though.
There is only 1 sensor per bank, it tries to figure out which cylinder is misfiring based on the timing, but very often if the misfires are pretty bad it will get confused like this.
...neighbor had 4 cylinder misfires...turned out to be two bad coils. Just a BTDT.
Although it does sound more like plugs (maybe plug wires).
only on full throtle in performance mode on higher gear. It turned out to be the plugs were going bad.
