1 BAR = 14.8 PSI right? So my UrS4 pushes almost 30 PSI. More....
If this is correct why do the magazines make a big deal of the new 911 Turbo pushing a "high 14 pounds of boost" Also, on the 5000 TQ what is boost pressure on that? My brothers will rocket up to 2.1 BAR, but on a 89 200TQ I test drove before I found my S4 wouldn't go above 1.2BAR. So what should the BAR Read on both the S4 and an older 5000 unmodified?
Many people calculate it as pressure ABOVE normal atmospheric. I believe your Audi's includes the 14.8 atmospheric in the total. I do not believe that the S4 engine is capable of an additional 30psi on top of that.
How did that 200TW feel? It is very possible that there was a leak somewhere in that system unless it calculates the boost differently. I don't know exactly how Audi sets up the different cars that have boost displays. My car doesn't have the display (92 only for the S4.)
Jim
93 S4
Jim
93 S4
get new pistons and rods, and balance it out. Probably get the cylinders honed.
For 30 pounds you would want the bring the CE down to atleast 9.5:1 ???
I have seen 33psi in bone stock long blocks. 450hp seems to be the limit before rods bend. All you need is an upgraded EM, turbo, exhaust, chip, injectors, and a very large IC.
After that, rods, pistons, and maybe cams or some other head work.
The 1.8T can also handle amazing boost levels.
UrMarvin
Audi Original "S" Cars
12
08-31-2007 10:50 AM
perfution
10
08-17-2003 07:47 PM
djillusion
06-23-2001 08:43 PM
