78' Audi 5000 rough idle problems/anyone know about the sudden acceleration recall they had
Guest
Posts: n/a
If anyone can give me any info on rough idling problems also on the recall that they had on the sudden acceleration problem which they recalled on my model. How do you tell if it was repaired?
Thanks,
Scott
AUDIs FOREVER!
Thanks,
Scott
AUDIs FOREVER!
Guest
Posts: n/a
First, have you checked/changed the basic tune-up parts? Next check into the fuel system...
how's the f-pump, filter, injectors, etc. Any vacuum leaks, hissing noises? Is the idle stabilizer sticking, or making noise?
The only "repairs" Audi made during the Unintentional Sudden Acceleration episode was to install a new shift lock device which prevented shifting of gears without the application of the brakes. They also changed the ISV (idle stabilizer valve.
If you can move your shift lever from park into any gear without stepping on the brake then the device was not installed or is no longer working.
HTH
Tom Serrago
1985 5KS Avant (original owner 190K miles)
1999.5 A4 1.8T QMS
HTH
Tom Serrago
1999.5 A4 1.8T QMS
Onearmedmidget
A4 (B7 Platform) Discussion
01-30-2006 06:47 PM
KOpork
07-19-2001 03:28 PM
