Automatic Transmission fluid level check.
Checked my transmission fluid this weekend after changing the filter.
Tha car appears to have been about 1.5 liters low out of 7 liters. Transmission is a 4HP18 (Zif 4 speed) with the new fill/check hole in the side of the transmission fluid pan.
I'm guessing the guy that touched this before me wasn't running the engine when he topped off the fluid.
I topped it off with the fluid temp at 40 degrees C (as per manual) and with the engine at idle, tranny in Park, heating and AC off.
What do you guys think?
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/9314.phtml">Clicky Here</a></li></ul>
belt change you need to remove the front bumper an the new A6. I imagine it's fun on an A4.
Thanks for the opinion on the ATF fill. I'm pretty sure only Audi has worked on the car. Of course since I do this "so often" if things aren't right the first thing I suspect is me, not the Audi mechanics. ;-)
..you have to pull the transmission(yes, I know it's on the opposite side of the motor). Something to do with having to loosen and tilt the motor to gain full access to the belt. I know what you mean, though; I do all my own work, and I'm always second-guessing myself until the car fires up and everyting works properly again.
TOMAS7
03-31-2008 05:26 PM
SpeedyG127
02-18-2007 03:34 PM
summersr
02-28-2002 01:41 PM
