Convert Non-quattro to Quattro
Guest
Posts: n/a
I have a 1986 Audi 5000 non quattro, would it be possible to add a quattro trany, drivetrain, axles, and rear suspention componts to make mine a quattro. I do the the repairs on my car by myself, I even put in a new engine in myself. so I would just be another project. If possible
Guest
Posts: n/a
Since 1986 was the NAmerican intro of the Quattro in the type 44's...
my guess is your chassis and floor should accommodate the quattro drivetrain with little or no modification.
I think the exhaust will need to be re-routed at a few points. The front and rear rotors are larger and are 5 lug, so besides a new brake system, you would need a new set of wheels and tires too.
IMHO, an easier and less expensive project would be to buy a later model 5KCSTQ fixer-upper.
Tom Serrago
85 5KS Avant
99.5 A4 TQMS
Tom Serrago
85 5KS Avant
99.5 A4 TQMS
Guest
Posts: n/a
Agreed...
a lot of the interior bits are different also (controls for the air lockers, that sort of thing). I've owned both, and I think the mounting points on the rear suspension are also different (A arms verses the trailing links). I think the only way this would be practical would be to get a wrecked TQ, otherwise the parts are just going to cost too much. Much better to just go get yourself a project car with the right bits already on it, those old 5KTQs are not that much money now anyway.
Guest
Posts: n/a
Don't Do it
Listen to Todd, buy a nicer old one, your money and sanity will go alot farther. I was considering this with an older 4000s, thank god someone talked me out of it......
You would effectively be making a slow car even slower.....
Buy a 86+ Type 44 TQ, and start fresh. I did, It' the best car I've ever owned....
Then again, if you are looking for a project, you certainly have one on your hands....Hey more power to you if you can pull it off, or rather put it on....!
Guest
Posts: n/a
You can't do it with a fwd 4000 because the floorpan is different. It may....
be the same for the 5000's, too. The bummer is that even the Coupe GT has a different floor pan than the Ur-quattro. At least from what I can tell from my Bentley manual.
MetA4
03-04-2004 12:24 PM
Ray Khan
03-08-2002 11:00 AM
4000, audi, b7, car, convert, converting, coupe, drive, drivetrain, gt, nonquattro, put, putting, quattro, train
