Do the 15"x7" wheels from an 99' A4 fit on the 92' 100V6?
Guest
Posts: n/a
Does anyone know if the 15"x7" wheels from a 99' A4 fit on 92'100V6? I am more concern about the offset. The offset on the 15"x7" wheels from a 99'A4 is 45mm. Currently I have a set of 15"x7.5" wheels with an offset of 37mm. All the aftermarket wheels for Audis that I have seen are usually 35mm or 37mm offset. The tires that I am putting on are 215/60 15". I am concern about rubbing in the wheel wells and clearance between the steering knuckles on the front struts and the inner rim's lips. I will like to hear from anyone out there with a 92'-96 A6/100 has a set of 15"x7" ET45 A4 factory wheels(either the earlier or later styles?) on it.
Audi S5 TC
Wheels & Tires Discussion
04-10-2007 01:28 AM
Anthony Chan
11-15-1999 08:57 PM
