modifications on audi 80Q
my car is a 1988 audi 80Q and i was wondering what kindof engine modifications i can do to my car to make it faster.. my dad has an S4, and it just doesn't compare anymore... thanx alot
~Paul
~Paul
...even get close to an S4. With a transplant though, you could blow the S4 away. There's not a whole lot available for the 10V motor and none of it helps much. Whatever you do, don't waste your money on the TAP chip. Chipping a Normally aspirated engine is useless.
well.. my dad has his S4 at 350 bhp right now and is inline for the 450 update... how much would a 20v turbo engine cost me?
A 20valve turbo will run you in the neighborhood of $3000. Then figure in another couple thousand to cover the labor of the engine swap itself, not to mention any parts that need to be freshened up or replaced during the process. That'll leave you with 227 hp in a 2900 lb 80--not bad, and you can go up to 350hp reliably with that engine.
A cheaper option is to swap in a 10valve turbo, as I have in my '89 80q. These motors are plentiful, and a complete swap can be done for the cost of a 20valve motor alone. I've got around 230hp right now, and there's room to grow that figure to around 270 or so. Good luck.
AUDI 90 (88)
40
01-23-2004 08:17 PM
///Mike@Boston Audi
12-08-2001 12:39 AM
