Pressure Bleeding
I am going to replace the clutch master cylinder aand the Bentley says to pressure bleed the system to 35 psi.
How exactly do I do this? I have seen pressure bleeders for $100 or so, but this seems like something that can be fabricated (mason jar, puch two holes in lid, couple of fittings and tubes, plus a pressure source -- like a tire inflator) Has anyone tried this before?
Anything to look out for in doing this job.
Thanks,
-- Tom
Thanks,
-- Tom
You can buy this at Bavarian Autosport and from Motive directly. It's pretty neat- you pump it up to a desired pressure, then let it out to bleed. You have a separate reservoir for the fluid, so you don't worry about running out of fluid. As you may tell, I haven't used it, even though I have one at home sitting on a shelf.
Worth the $40- I've talked to several people who have used it with great success on Audis.
TM
TM
I've done what you propose more or less. drilled a hole in a cap that would fit on the reservoir, put a schraeder valve in and pumped up like 15 psi. works fine. cant remember exactly where I got the valve. have used the same valve screwed into an sliced up inner tube, clamped to intake ductwork, intercoolers etc to check for leaks also.
Zold-manS8
06-04-2006 10:55 PM
monsterness
01-15-2006 02:49 PM
RNO.Audi
01-08-2003 08:17 PM
4k4snow
11-11-2002 05:29 PM
K-solo
06-27-2002 12:31 PM
