rattleing sound from underneath?
Im assuming its my CatConverter?? if so how much does it cost to replace/repair one of these??? i know my car has two ?? do they com togther when i buy them or what ... is that even the problem?? i get a lot of emisions all the time... ?? if i dont repair it anytime soon will it hurt my car or just continue to pollute the enviroment?? please help!!!
thanks guys!
thanks guys!
This is a common problem.
There is an Audi recal on this, for one of the cats, (drivers side). Go to an Audi dealer and see if the recall applies to your car. If yes, they will replace the cat for free.
If not, here are your options :
1) Have Audi dealer replace, about $800 part (each cat) and labor.
2) Try to get the OEM cat from Blaufergnugen.com, about $500 for the cat.
3) Try to buy an aftermarket replacement cat from (try various Audi parts vendors) about $400 each
4) Buy a universal cat unit (about $80 to $150) and have an exhaust specialty shop cut out your old one and weld in the new one.
5) Remve the cat assembly from the car, bash out what is left of the ceramic cat substrate (thats what is rattling), and put the assembly back on the car. Cost = minimal, but it is a federal (EPA) crime, and your car MAY not pass emmisiions testing.
Assuming I'm correct and don't have you confused with someone else, but didn't you say you've had some other problems. If so, I think I'd be going back to the dealer/used car place/from whomever you purchased the vehicle and telling them they can take it back.
The catalytic converters on these older models are a common failure. BTW, has anyone had a second set fail?
Here's where I bought both of my direct-fit cats:<ul><li><a href="http://www.discountconverter.com/converters/audi/audi_direct_fit.cfm">http://www.discountconverter.com/converters/audi/audi_direct_fit.cfm</a</li></ul>
I think the maintenance costs are going to get the better of you.
I own the same make and model, even with me doing the work it's still a lot of money in parts to maintain these models. Plus I think my car was maintained better by the original owner.
My current repairs would include (Parts):
Water Pump/Belts/tensionner $300
Front struts $110 (done!)
A/C problem $50 - $1500
Cats (they are starting to smell)$800
Leaking Gaskets $400
Improvements
(I think this car is slow).
Wheels /Tires $1200
Throttle body Mods $300
CAM's $895
Port & Polish $2000
At this point I'm considering looking for an Audi
with a stick shift and a Turbo I5 engine.
Improvements
Wheels /Tires $1200
CAM's $895
Port & Polish $2000
A bad muffler or resonator can rattle also, so it is not necessarily the cat. The only way to find out for sure is to put the car up so you can hit the cats and the mufflers to see which one has loose pieces inside.
As far as the emissions go, you wouldn't be able to tell the difference between cat or no cat without hooking your car up to a tester, unless you are referring to the rotten egg smell. Also, in my case, the cat was hardly even doing anything. If your car is running efficiently, the cat is really just cleaning up any unburned remains, which should be neglibible. If they are excessive, then your car is not running properly and your cats are being overworked.
Ummm well let me see..
1.small crack in left head light
2. right fog light cracked.
3. side door dent
4. engine jumps around a lot
5. jolts all the time when speeding..
6.weird gas milelage 5.0 when going up a hill..?
7. needs rebuilt brake calipers. (front)
8. possible timing belt replacement.
9.139k
10. had a new trans put in 10 months ago.
11. new oxy sensors as of a month ago..
12. i want a high millage a6 PLEASE GOD!
13.god damn you audi.
14. i dont have any money to repair anything.
15. only gas money..
16.interior is dirty..
17. juice stains.
18. i smoke.
19. car needs new cat's i presume...
19. ill take a high miliage 92 S4..
20. non-stock tape deck .. only two speakers work.. and the suck..
21. i love my car even though it has problems.
22. i see better audis for less then i payed.. (damnit!!)
23. please trade me...
24.. its a 100cs????
3. side door dent
9.139k
17. juice stains.
18. i smoke.
