S8 Press Release
Guest
Posts: n/a
AUDI AG<br>Public Relations<br>Communication: Product and Technology<br>D-85045 Ingolstadt<br>Tel.: +49 841 89-32100/-37947<br>Fax +49 841 89-32817<p>March 1999<p>Audi News Geneva 1999<p>The equipment and data specified relate to the model range available in Germany. We reserve the right to make changes. Errors and omissions excepted.<p><br>A luxurious top-class car for the enthusiast<p>Audi S8<p>With its S8, Audi offers the discerning customer a perfect synthesis of luxurious top-class atmosphere and superior power. In combination with unique technical features such as the all-aluminium Audi Space Frame (ASF) and the quattro permanent four-wheel drive system, this makes the top-of-the-range model from Audi a leader in the field of automotive construction.<p>The Audi S8 will appeal first and foremost to drivers with an enthusiasm for technology and high performance. As a true Audi S model, it offers supreme sporting performance combined with style. In appearance, the S8 differs only slightly from the A8: it has outside mirrors made of polished aluminium and special 18-inch îAvusî cast alloy wheels. This top-of-the-range model from Audi can also be recognised by the small emblems on the front and back and the combined aluminium-look tailpipe trim.<p>Naturally, the S8 has also benefited from all of the improvements made to the A8 as part of the recent product enhancement program at the beginning of this year.<p>The sports suspension fitted as standard and the optional enhanced-comfort suspension, which will be appreciated by long-distance drivers in particular, are made entirely of aluminium.<p>The front and rear disc brakes, with their 17-inch ventilated discs and aluminium callipers, have also been upgraded to match the superior performance of the engine. The 8J x 18 îAvusî cast alloy wheels are fitted with 245/45 ZR 18 tyres.<p>The V8 engine with its displacement of 4.2 litres has been revised for maximum power, starting with optimised intake paths and low-friction roller cam followers for the valve gear and extending to adapted timing for the variable intake camshafts and a two-stage switchable-flap intake manifold. These improvements and innovations add up to a rated power of 265 kW (360 bhp) at 7,000 rpm and an impressive maximum torque of 420 newton-meters, available from just 3,400 rpm.<p>To transmit this power, S8 customers have the option of a manual 6-speed gearbox or the 5-speed tiptronic transmission with Dynamic Shift Program (DSP). This can be operated by means of fingertip switches on the tiptronic sports steering wheel that is available as an optional extra.<p>The continuous flow of power of the engine allows the cruise control now fitted as standard to the S8 to maintain the speed selected by the driver effortlessly, even on hills. The discreet grey dials and white pointers of the instruments keep the driver informed about the S8ís speed and other operating parameters. The speedometer is calibrated non-proportionately, making it easier to read the carís exact speed between 0 and 90 km/h and therefore stay below speed limits.<p>As with all Audiís S models, the S8 is available only with permanent four-wheel drive. This offers the assurance of optimum traction and directional stability and also ensures mobility even in difficult situations. On the Audi S8, a self-locking Torsen centre differential is used to distribute the power between the front and rear wheels as required.<p>All Audi S8s are fitted with the Electronic Stability Program (ESP) as standard. ESP continuously monitors the parameters critical for the maintenance of the carís stability and intervenes automatically if there is any risk that it might skid. The ESP control unit calculates the momentary state of the vehicle from the wheel speeds and data supplied by the anti-lock brake system (ABS), the traction control system (ASR), and by sensors that detect the steering angle, yaw moment and lateral acceleration. <p>Each steering angle is associated with a particular yawing moment which depends on the speed of the vehicle. If it exceeds this value, the car will oversteer and may skid. If it is lower than this value the car will understeer, that is to say the front wheels will tend to run wide when cornering.<p>ESP counteracts oversteer by selectively braking the front wheel on the outside of the bend, while in the case of understeer, it briefly brakes the rear wheel on the inside of the bend. The combination of permanent four-wheel drive and ESP makes the Audi S8 one of the safest cars to drive that money can buy.<p>The Audi S8 combines an extremely high level of active safety with an equally high level of passive safety. This is because of the aluminium body, which features the Audi Space Frame (ASF). Naturally, the S8 also has a highly advanced safety system incorporating two front airbags and side airbags integrated into the seat backs at front and rear, complemented by SIDEGUARD, Audiís head-level airbag system.<p>Exclusive character is the distinguishing feature of the Audi A8ís interior. The individual elements, which are made of high-quality materials, match each other in every detail, combining to form a harmonious whole.<p>There is a choice of nine colour combinations for the interior. The headliner is in a rich black colour. The previous silk nappa leather range has now been replaced by Valcona leather. The standard sports seats can be upholstered with a combination of leather and Alcantara. There is a choice of luxurious trim options, including myrtle (dark), birdseye maple (light) and carbon fibre, to match the colour combination chosen for the interior.<p>As in the Audi A8, the S8 can be supplied as an optional extra with windscreen heating which does not use visible wires. Instead of these wires, which can impair visibility, it uses as a heating element the layer of metal incorporated into the laminated windscreen of cars with heat-absorbing glass. Its maximum output of 1,000 watts ensures that condensation is cleared rapidly and that even after a night in the open at sub-zero temperatures, any ice melts quickly.<br>
Guest
Posts: n/a
<TABLE CELLSPACING="0" CELLPADDING="0" BORDER="0"><br> <TR><TD ROWSPAN="10"><IMG SRC="../pix/p.gif" WIDTH="10" HEIGHT="1" BORDER="0"></TD></TR><br> <TR VALIGN=TOP><TD COLSPAN=4 WIDTH="600" HEIGHT="60"><BR><FONT SIZE=4 FACE="GENEVA, ARIAL, HELVETICA"><br><B>Technical Data - Audi S8 (265 kW)</B></FONT></TD></TR><TR><TD><IMG SRC="../pix/p.gif" WIDTH="128" HEIGHT="1" BORDER="0"></TD><TD><IMG SRC="../pix/p.gif" WIDTH="20" HEIGHT="1" BORDER="0"></TD><TD><IMG SRC="../pix/p.gif" WIDTH="352" HEIGHT="1" BORDER="0"></TD><TD><IMG SRC="../pix/p.gif" WIDTH="10" HEIGHT="1" BORDER="0"></TD></TR><p><p><br> <TR VALIGN=TOP><TD></TD><TD></TD><TD WIDTH="472" HEIGHT="30"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="3"><br> <B>German sales specification - Status: March 1999</B></FONT></TD></TR><p><p><br> <TR VALIGN=TOP><TD Align=right><br> </TD><TD></TD><p><p> <TD><br><table border="0" cellspacing="1" cellpadding="3" bgcolor="#CCCCCC"><br> <TR bgcolor="#FFFFFF"><TD WIDTH="200"><IMG SRC="../pix/p.gif" WIDTH="130" HEIGHT="1" BORDER="0"></TD><TD WIDTH="400"><IMG SRC="../pix/p.gif" WIDTH="250" HEIGHT="1" BORDER="0"></TD></TR><br> <p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Engine / electrics</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Engine type</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">V8 spark-ignition engine, 2-stage variable-length air intake, DOHC</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Valve gear / number of valves per cylinder</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Variable camshaft timing, roller cam followers with hydraulic lash compensation / 5</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Displacement in cc / bore x stroke in mm / compression ratio</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">4172 / 84.5 x 93.0 / 11.0</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Max. power output in kW (bhp) / at rpm<BR>(acc. to 80/1269/EEC)</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">265 (360) / 7000</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Max. torque in Nm / at rpm<BR>(acc. to 80/1269/EEC)</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">430 / 3400</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Engine management</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Motronic ME 7.1: fully electronic sequential injection, coordinated engine-torque control, hot-film air-mass metering, electronic accelerator, mapped ignition with solid-state high-voltage distribution, cylinder-selective knock control with two sensors, adaptive oxygen sensor control</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Exhaust emission control</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Air-gap-insulated exhaust manifold, two 3-way catalytic converters, two heated oxygen sensors</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Emission category</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">EU III D</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Alternator in A / battery in A/Ah</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">150 / 450/92</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Drive / transmission</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Drive layout</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Permanent all-wheel drive with Torsen centre differential and Electronic Stability Program (ESP)</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Clutch</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Single dry plate clutch, dual-mass flywheel</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Hydrodynamic torque converter with lock-up clutch</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Gearbox type</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">5-speed manual</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">5-speed tiptronic</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Gear ratio in 1st gear / 2nd gear</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">3.500 / 1.889</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">3.571 / 2.200</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Gear ratio in 3rd gear / 4th gear</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1.320 / 1.034</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1.505 / 1.000</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Gear ratio in 5th gear / reverse gear</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">0.857 / 0.730</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">0.804 / -</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Final drive ratio</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">3.455 / 4.111</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">4.095 / 3.730</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Running gear / steering / brakes</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Front suspension</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Four-link with double upper/lower wishbones and anti-roll bar</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Rear suspension</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Track-stabilising trapezoidal-link with wishbone, tubular anti-roll bar</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Steering / steering ratio / turning circle in m (D102)</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Maintenance-free power-assisted rack-and-pinion steering / 15.7 / app. 12.3</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Brake system front/rear</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Dual-circuit, diagonally split, ABS/EBD, servo; ventilated discs front and rear;<BR>twin-piston calipers at front</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Wheels / tyres</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">8 J x 16 cast alloy / 245/40 ZR 18</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Performance / fuel consumption / acoustics</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Maximum speed in km/h</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">250 (governed)</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Acceleration, 0-80 km/h / 0-100 km/h in s</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">4.0 / 5.4</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">4.8 / 6.6</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Fuel grade</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Super Plus/Euro Super unleaded, 98/95 RON</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Fuel consumption, urban/extra-urban/total, l/100 km <SMALL><SUP>1)</SUP></SMALL></FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">20.8 / 9.7 / 13.7</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">21.7 / 9.5 / 13.9</FONT></TD><br> </TR><p> <TR><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">CO<SMALL><SUB>2</SMALL></SUB> emissions, g/100 km <SMALL><SUP>1)</SUP></SMALL></FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">329</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">334</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Standing / drive-past exterior noise level in dB (A)</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">84 / 74</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">85 / 74</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Servicing / warranty (German market)</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Oil change every ... km / inspection every ... km</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">15,000 (maximum 1 year) / 30,000</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Vehicle / paint / rust penetration warranty</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1 year, unlimited distance / 3 years / 12 years</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Insurance classification in Germany</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">32 (fully comprehensive) / 39 (partial) / 24 (third party)</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Weights / loads</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Unladen weight in kg / gross weight limit in kg</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1730 / 2330</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1750 / 2350</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Axle load limit at front / rear in kg</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1230 / 1230</FONT></TD><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">1250 / 1230</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Trailer load limit, unbraked in kg</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">750</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Trailer load limit at 8%/12% gradient, braked in kg</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">2300 / 2300</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Roof load limit in kg / nose weight in kg</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">100 / 95</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Capacities</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Cooling system volume (incl. heating) in l</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">11.0</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Engine oil capacity (incl. filter) in l</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">7.5</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Fuel tank capacity in l</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">90</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD bgcolor="#999999" colspan="3"><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2"><b>Body / dimensions</b></FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Body type / number of doors / seats</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Aluminium: Audi Space Frame (ASF) / 4 / 5</FONT></TD><br> </TR><p> <TR><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Drag coefficient c<SMALL><SUB>D</SMALL></SUB> / frontal area A in m<SMALL><SUP>2</SMALL></SUP></FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">0.29 / 2.25</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Length (L103) / width excl. mirrors (W103) /height (H100) in mm</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">5034 / 1880 / 1418</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Wheelbase (L101) / track front/rear (W101/W102) in mm</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">2880 / 1591/ 1580</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Height of loading lip in mm (H195)</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">624</FONT></TD><br> </TR><p> <TR VALIGN=TOP><br> <TD><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">Luggage capacity in l, acc. to VDA block test method (V210)</FONT></TD><br> <TD colspan=2><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="1">525</FONT></TD><br> </TR><br></TABLE><br><font size="1"><SMALL><SUP>1)</SUP></SMALL> According to 93/116/EU</font><BR><br>Scroll down until table appears...<p> <TR><TD COLSPAN="3" ALIGN="LEFT" NOWRAP><FONT FACE="GENEVA, ARIAL, HELVETICA" SIZE="2" Color="#0033FF"><BR><A HREF="#0">Top</A></FONT></TD></TR><p> <br></TABLE><br>
