ABS Lamp On, Brake Lamp Beeping & Flashing
Guest
Posts: n/a
I had a problem with my left front tire, a slow leak. I had to use a tire/wheel that was not the same size as what I am using on the car. I drove home this way about 15 miles. There were no problems encountered, nor any warning light. But now when I got my original tire/wheel back and reinstalled on the car, but after about a half hour later, the yellow ABS warnig light lit up, and the Brake waring light beeped a couple of times, and then keeps flashing.<p>Awhile back I had the speedo tested, and when the car came off the rollers, this happened then, but after shutting the car off for a bit, it went away. But this time it seems here to stay! Any suggestions???
AKS4
06-09-2005 09:08 PM
