Motorsport Discussion Discussion forum for everything racing-related
Anyone have the formula for how much degrees of banking increases cornering G's?
Old 03-28-2004, 06:55 PM
LCP
AudiWorld Expert
LCP's Avatar
Default Anyone have the formula for how much degrees of banking increases cornering G's?
I.e., on a 30-degree banked corner, how many more lateral G's does the 30 degree banking allow you to endure (assuming you could corner at 1g without the banking)?
Old 03-29-2004, 02:26 AM
Elder Member
ryoung's Avatar
Default g / cos(angle)
g = g<sub>0</sub> / cos(angle)
If a 30 degree bank and one g without banking,
g = 1.0 / cos(30)
g = 1.0 / 0.866
g = 1.16
Old 03-29-2004, 06:15 AM
LCP
AudiWorld Expert
LCP's Avatar
OK, that makes sense, but it just "seems" too low IMO.
Old 03-29-2004, 06:32 AM
AudiWorld Uber User
NASA racer's Avatar
Default mostly you get positive G
which adds adhesion by adding "downforce" to your vehicle.
Old 03-29-2004, 06:57 AM
LCP
AudiWorld Expert
LCP's Avatar
Default That's kind of what I'm after. It seems like it would be some kind of combination formula.
And for instance, if there was only a 5 degree banking (which on a road course is huge and can let you corner a lot faster than you otherwise would on a neutral camber corner), by using only the cosine angle formula Randy posted, you could only increase lateral cornering G's 0.4% (the cosine of 5 degrees is 0.996; 1/0.996=1.004).
Old 03-29-2004, 07:02 AM
Elder Member
ryoung's Avatar
Default Seemed low to me also, ....
Until I thought about a winged Indy car on slicks exiting an oval corner along the wall at 200 mph. The car could probably corner at 3+g on the flat at that speed, and with 30 deg banking it becomes 3.5+g. With a wall only a few inches away, it probably doesn't feel low at all.
Old 03-29-2004, 07:47 AM
Junior Member
Mark Dalen's Avatar
Default Too low
You are missing a major factor - the g's created by cornering also add to the normal force of the car. Let's use a 45 degree bank. There is .707 g normal force and -.707 g cornering (weight of the car trying to fall down the banking. Now for whatever cornering load you can carry (we will call that G) you have that force (G) acting in the + direction laterally, and .707 G adding to the normal force.
So, corneing force is G - .707 (times the weight which is equivalent to 1 g) and normal force is .707 G + .707 w (which again is equvalent to 1 g. Sloving for G yeilds ~4.8g's (through the perpendicular to the track. I did this quickly so I may have missed something and this is based on tires that can do 1.0g so the coefficient of friction is 1.0.
But you can't really do this - mostly because when you load a tire that much, the coefficient of friction falls way off.
Bottom line is I don't think you can use a formula to estimate this, unless you are at very low banink angles. If you are taling 5 degrees, then the loading is not that high so the coefficient of friction would be relatively constant and this formula would work. Right now, I am too lazy to derive the formula for any banking angle.
Old 03-29-2004, 08:37 AM
Junior Member
Mark Dalen's Avatar
Default Lazy
My net connection went down for a while, so I had nothing better to do, so here is the equation. I think I have it right - this is based on tires that do 1.0g level on a banked track of angle a. G is the mazx g's you can pull, measured parallel with the car. This is the G associated with the velocity so measured g would be lower by sin(a) due to the tilt of the car (In other words, 0 g's would be measured when there is some speed, not at 0 speed.) Again, this does not factor the drop off in coefficient of friction which is VERY significant as loads go up.
G = (cos(a) - sin(a))/(1-cos(a))
Old 03-29-2004, 09:54 AM
LCP
AudiWorld Expert
LCP's Avatar
This is what I was imaging would be the case. I just couldn't formulize it.
Old 03-29-2004, 09:59 AM
LCP
AudiWorld Expert
LCP's Avatar
Default Well, wait a minute. The formula doesn't seem to work.
I just tried it with 45 degree banking, and it came out as zero, and many other angles seemed out of whack too.
Quick Reply: Anyone have the formula for how much degrees of banking increases cornering G's?
