b6S4..ne1 install the Schroth quick-fit harness OR Topspin? Any "problem" areas? Discuss please.
Ya...is yours the "quick-fit" style?
Jeff's same as the auctioned set at Tremblant? I really don't want to cut anything.
if you want to attach to the factory seat belt mounting location (a good idea, IMHO), you'll need to cut a small slot. I returned the old car to Audi with the slots still there, and no one noticed.
I'd be suprised if replacing the trim you needed to cut was more than $100-150 or so, if that really bothered you.
Everyone else that is using the quick-fit harnesses are attaching the outboard belt to the seat somehow (caribiner, etc).
and installed them in time to make the next run ....after a considerable amount expletives. :-)
I have the booklet from Tremblant that describes them as Schroth Quick-fit harnesses.
Additionally, the outboard attachment points are the issue on the b6 per your comment.<ul><li><a href="http://www.evolutionsports.com/productDetail.cfm?catID=72&ProductID=1957">htt p://www.evolutionsports.com/productDetail.cfm?catID=72&ProductID=1957</a</li></ul>
seat bottom that go to the seat tracks. Easy attachment points to secure to for the seat belt ends. On the b6, the outside belt is integrated into the track/mechanism and the seat guides go to the rails/tracks and no piece of exposed seat to attach the outboard belt to.
Love your Imola/wheels are perfect too.
