Good brake pads for track and street?
As much as I like my Mintex redbox pads on the streat, they are not so good on the track. Does any one have suggestions on pads that I can use on the track as well as the streat? I am willing to give up some street braking performance if I can stop boiling my brake fluid on the track.
Thanks,
--Leszek
Thanks,
--Leszek
I have Audi pads for the street and Mintex Ctech for the track. The Ctechs just didn't give inital bite that the factory pads gave. I need that for the stop-go traffic in town.
Two pair for a number of reasons. I run one set of pagids for AX and street, but track is a whole 'nother world. It is easy to have some serious overcooking damage, including cracking and delamination if you aren't running ducts. Replacing the pads allows you to stay on top of damage and look at the brake lines (if you went aftermarket). It will also be a good time to bleed the system. It is eventually more cost effective anyways.
You might look at some monster racing pads: Porterfield R4 or 3000, that are unstreetable, but give uber grip when hot.
My previous RedBox pads didn't hold up at ThunderHill in January. They smoked and faded and my pedal was very spongy after two days. So I put C-Tech pads up front and braided lines all around. Although better, I still had a mushy pedal at the end of the day at SIR.
I think I'm going with a caliper upgrade.
Good luck,
Rich
Good luck,
Rich
I still boiled ATE super blue and the brakes still got mushy, and somewhat faded. Better than stock, but not a few hundred bones better.
I say, if you're gonna muck with A4 brakes at all, go for at least the BIRA setup, which is "reasonably" priced. If you do a lot of track time though, a step up to better rotors may be in order, like the kits from Vortrag and Mov'it.
Warren
Warren
I am switching the fluid in my TTQ on the 25th to SuperBlue Racing Brake fluid.
Its specs are as follows:
Dry Boiling Point: 536*F, +122* above DOT 4 spec
Wet Boiling Point: 392*F, +113* above DOT 4 spec.
Your car and mine come with DOT 3 brake fluid! The boiling point is even LOWER than DOT 4!
Before you go and do a complete brake upgrade, try upgrading your brake FLUID! I am sure the C-Tech pads are just fine, it is the fluid that is the problem. You are still generating the heat no matter what pads you use.
The cost of the fluid is $13/liter. you will need just over 1 liter to completely drain the brakes and change the fluid. Try and find a place that can do a fluid replacement under PRESSURE! You will be amazed at the great feeling brake pedal!
I got my fluid at Camra Motorsports, http://camramotorsports.hypermart.net/
Good luck.
Larry
180TTQ Garrett, H&R, Borla(3/25), Hardwired V1, Custom Stereo<ul><li><a href="http://larrytt.tripod.com">http://larrytt.tripod.com</a</li></ul>
Good luck.
Larry
Changing to SuperBlue fluid and RedBox pads was my first step. Going further to C-Tech pads and stainless steel braided lines was my second step. I'm thinking my third step will be slotted A8 rotors and either Alcon or AP Racing calipers.
Thanks for the suggestion. I hope it proves enough for you and your TTQ.
Rich A4 1.8TAQMS
Rich A4 1.8TAQMS
I am trying to avoid doing a total brake upgrade to my TTQ!!! I have horrible stock brakes. They fade on the street! I am going to try SuperBlue and then Mintex RedBox for the track.
Worst case scenario I will get something like the soon to be released AWE-Tuning Boxter 4 piston brake upgrade. If I do that I will have to swap back and forth for the winter as the Boxter calipers won't fit inside my 16" Steel winter wheels!![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Let me know what you end up doing.
Larry
180TTQ Garrett, H&R, Borla(3/25), Hardwired V1, Custom stereo<ul><li><a href="http://larrytt.tripod.com">http://larrytt.tripod.com</a</li></ul>
Larry
