Problems doing heal and toe in S4
I find it almost impossible to do heal and toe in the S4 (even if I use my big toe on brake and little toe on throttle). The problem is that the brake and throttle pedals are too far apart for my small feet and the brake is too high in relation to the throttle.
Has anyone fitted larger pedal covers, does this help? I know on most cars you can adjust the height of the brake pedal. Can you do this with the S4?
Step on the brake with the left most ball of your foot... and just rotate your foot onto the accelerator.
Pretty easy... and pedal placement isn't really that bad... it's not perfect .. but it's very doable.
Good luck
Good luck
A8L 2000 Ohio
03-09-2007 07:16 AM
