Who's doin' Speedventures @ Fontana on June 18th and or 19th??????
<a href="http://www.speedventures.net/6-18-2005_event.asp">Speed ventures @ Fontana</a>
Infield course, garages are available, I'm doing just the Saturday, souldn't be too hot (if we've got "june gloom" weather), especialy in the morning.
<img src="http://www.speedventures.net/graphics/Cal_Speedway_infield.jpg">
On the big course, that 1st. left turn into the infield looks spooky, you can see Mr. retaining wall waiting for you if you screw up!!
I figured I'd try the infield course 1st, it loooks allot tamer, am I wrong???
I don't want to face allot of walls coming out of corners if screw up!!
BWAAAAAAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA.
Actually the infield course is challenging.
You enter the garages down there on the left:
<img src="http://www.kansaswindpower.net/Sun%20latest_eit_304_full-6-24.gif">
The only scary thing about the big track is entering the oval at speeds you're not used to going (over 160 in my case). Entering the infield, T3 and T4, is just a huge braking exercise. The only bad thing that can happen is you can over cook it and you have to run around the entire oval to get back on the track (not at speed of course). No walls come into play unless you really mess something up going through 8 which is a chicane. The facility is gorgeous and definitely worth the time and money.
I found the infield very slick and kept fighting the chassis in regards to air pressure and shock adjustments. The lower air pressures seemed to do more good, but T7 is still a PITA... off camber decreasing radius slick bastard of a turn. There are a couple chicanes which are fun and they have some great curbs to crawl.
Depending on your schedule and price difference, the speedventures event might fit the bill for you. Just be sure to pencil in the big track in the future; if you're a L.A. local you HAVE to run that track at some point. I'm sure you'll get there and just wish you could take a turn around the oval
Overcast in the morning, burning off in the afternoon, temps in the high 80's.... :-)
My gearing is pretty short:6,000rpm is good for about 120mph, I'm afraid I'll thrash my engine running down the front straight @ that rpm all day!!! :-(
whose the idiot racing at Buttonwillow June 11th? ;-P<ul><li><a href="http://www.weather.com/activities/other/other/weather/tenday.html?locid=USCA0146&from=search_10day"> http://www.weather.com/activities/other/other/weather/tenday.html?locid=USCA0146&from=search_10day</a</li></ul>
