Broken lug nut what to do!!!!!!!!???????
If so, take off the wheel, spray PB Blaster around the lug, give it a chance to work in. Then clean off the threads of the protruding lug with brake cleaner and use a plumber's pipe wrench to crank out the lug. Pipe wrench has directional teeth to grab the lug. It will destroy the threads.
If not, drill out some more of the lug nut. Protect the inside edges of the wheel bolt hole with a plastic sleeve or cardboard tube.
brought it to the shop and they are tellingme they can't drill out the bolt that i need a new wheel hub and new wheel bearing. what do you guys think of this??????
