New Member Welcome Area We've gathered the info you need if you are new to the AudiWorld forums
2009 Audi A4 B8 Avant rough startup followed by white smoke from engine bay.
Old 06-30-2024, 05:36 AM
GordonA4's Avatar
Default 2009 Audi A4 B8 Avant rough startup followed by white smoke from engine bay.
Good day All
I have a 2009 Audi A4 B8 Avant with 192 951 km's on the odometer.
I started my car yesterday & immediately noticed that it did not sound normal. It had a very rough idle & a few seconds later , white smoke started coming out from the engine bay acompanied by a rubber/plastic smell.
I switched off immediately & opened the bonnet to see what's going on. I then left the car off for for half an hour & then tried to start it again but it would not crank as if the engine had seized up. There's now only a click from the engine bay & nothing else when I try to start.
I bought the car in August last year on 189 390 with a full service history from the agents up to 93 100 & then services at non-audi agents up to 154 387.
After purchasing the vehicle I took it to a VW/Audi specialist in my area to do a major service at 189 641.
They fitted the following parts : Oil filter , pollen filter , spark plugs , 5W40 engine oil & Sump plug. I asked about the timing chain but they advised that the timing chain doesn't need to be replaced yet.
The car was driving okay after the service although I was a bit concerned about a slight rattling sound from the front of the engine. I did ask them about the rattling sound but they didn't sound too sure about what could be causing it?
Last week I started getting an oil smell in the cabin & also noticed a bit of white smoke coming out the exhaust. I checked the oil level which was normal.
I hope I didn't cause the damage by allowing the petrol attendant to top up my oil with 10W40 as they did not have 5W40 in stock when my oil light came on a few months ago?
I now also suspect that the timing chain may have stretched & jumped a few teeth which caused the problem I now have.
Has anyone had a similar experience as I am now fearing the worst when have my car towed back to the VW/Audi specialist for them to assess the damage?
Please advise if the timing chain should have been replaced on the last service at the VW/Audi specialist at 189 641?
Thank you in advance
Old 06-30-2024, 05:50 AM
JohnnyJ's Avatar
As always, what fault codes do you have?
Old 06-30-2024, 06:16 AM
GordonA4's Avatar
Hi Johnny
Apologies , I'm a newbie & this is my first thread on Audiworld . I'm not an experienced mechanic though & I don't have a diagnostics tool yet.
My car is still at home & I was planning to take it back to my mechanics when I'm ready to do that.
Could you please advise me on good diagnostic tool I could buy to check the fault codes & then I'll let you know which codes are detected?
Kind regards
nl9
05-21-2021 01:08 PM
Andrey Dimov Georgiev
A7
02-21-2020 01:55 AM
ebay2478
10-18-2004 06:35 AM
tird
03-27-2000 06:34 PM
Quick Reply: 2009 Audi A4 B8 Avant rough startup followed by white smoke from engine bay.
