IE: 2012 Audi a6 c7 abs tpms no communication with abs control unit
Hi all problem 2012 a6 c7 abs tpms parking brake fault lights on dash .u10bd00 u111300 u012100 no communication with abs control unit .any help greatly appreciated. Also Windows and central locking not working
Hello, I have the same problem on my 2014 a6. What was the solution to your fault?
2014 A6 C7 abs tpms traction control power steering not working sunroof not working.
Hello. I found the problem, at least it was in my case. The J533 did not communicate well with the rest of the modules.
So I simply disconnected the module ( its located under the rear seat ), connected it again ( was looking for some corroded pins in connector, everything was fine).
And also near the module is ground point, did the same thing ( disconnect->connect ).
After that, I drove my car 2k kilometers and no error on the dash and also VCDS scan is clear.
Here is the diagram of all modules that are going connected with J533, so all the codes that are mentioned before are related with this module....
I hope that at least I helped someone because i had a really long journey to solve this.
I found this on Ross-tech forum and the idea what to do was born... Here is the thread where I fount the diagram. https://forums.ross-tech.com/index.p...s/25524/page-2
galaxys (10-20-2022)
If you are driving a diesel A6 get the DPF's checked. My "ABS problem" was actually nothing to do with the ABS and was part of a general malfunction due to blocked DPFs. Removed, re-mapped and better than new!
Dan_00
New Member Welcome Area
12-13-2021 04:48 AM
Neo1130
06-25-2008 09:26 AM
Lys2KS4
06-30-2004 07:56 AM
Just went out for a drive in 1" of snow and my RE730's - Result: ABS!ABS!ABS!ABS!ABS!ABS!ABS!ABS!ABS
Mark P
12-08-2000 11:02 AM
