I need to get some parts cleaned - any suggestions on shops ?
Previous owner of A6 ran Dino Oil :-(
Inside of the engine has brown caked crap. Want to at least get valve covers and oil sump thoroughly cleaned, maybe bead blasted or ultrasonic cleaned.
Turbo Oil lines also need to be cleaned, although it may be safe just to replace with ss lines.
then drain the oil and see if that made a difference.
I usually run a can of SeaFoam in the oil prior to changing it, seems to keep all the tarnish off and the oil drains very easily.
YMMV.
YMMV.
pour the can into the crankcase, same way you add oil.
What you are referring to is using a vacuum line to suck the Seafoam into the intake manifold, where it is burned with the fuel/air. It will smoke using this method, but not by adding it to the crankcase or adding a can when refueling (like Techron)
I've used the manifold vacuum method on my ticking lifters on my Miata. Good lord, Mosquito abatement didn't need to come my neighborhood after that.
Seafoam is good stuff.
markN1689
Audi A3 / S3 / RS 3 MKII
190
04-25-2024 09:14 AM
LaserSVT
64
01-19-2016 04:26 PM
CPLYONS
09-07-2015 07:19 PM
stormchaser1967
09-02-2015 08:48 AM
