Mammoth skier/boarder BT: Best driving route from up here?
Old 02-02-2009, 10:13 AM
AudiWorld Expert
Sia Bani's Avatar
Default Mammoth skier/boarder BT: Best driving route from up here?
Do any of you go to Mammoth regularly? Is there a route you go other than the suggested Google chaos:
<a href="http://www.tpiwwp.com/v2/show.php/606_222009110900AM.png.html" target="_blank"><img src="http://www.tpiwwp.com/v2/out.php/i606_222009110900AM.png" alt="Free Image Hosting At site" /></a>
Looks like parts of the 120 are closed during the winter, when I drag to my own travel path. I took this going down to Whitney in the summer, lots of backroads, hence why google suggests all hwy, but it was shorter regardless:
<a href="http://www.tpiwwp.com/v2/show.php/607_222009111107AM.png.html" target="_blank"><img src="http://www.tpiwwp.com/v2/out.php/i607_222009111107AM.png" alt="Free Image Hosting At site" /></a>
Any thoughts?
<a href="http://maps.google.com/maps?f=d&source=s_d&saddr=mountain+view,+ca&daddr= 37.735969,-119.94873+to:Mammoth+Lakes,+CA&hl=en&geocode=&mra= dpe&mrcr=0&mrsp=1&sz=7&via=1&sll=38.104305,-120.525513&sspn=3.613173,7.075195&gl=us&ie=UTF8&ll =37.635985,-120.613403&spn=1.818299,3.537598&t=h&z=8">Google maps to toy with</a>
TIA!
Old 02-02-2009, 11:18 AM
Member
Audi-Sav's Avatar
If 108 through Sonora is open, take that. The Tahoe route takes forever.
Old 02-02-2009, 12:01 PM
DBenn (Derek)'s Avatar
Default During the winter I take 80 to 395. I don't even bother with 50 to South Lake
50 is too slow and I hate that road. The passes like Tioga are generally closed for the winter so I've always gone the 80 route.
Old 02-02-2009, 03:51 PM
AudiWorld Expert
Sia Bani's Avatar
Default Sounds closed:
<a href="http://www.dot.ca.gov/hq/roadinfo/sr108">http://www.dot.ca.gov/hq/roadinfo/sr108</a>
Old 02-03-2009, 09:11 AM
AudiWorld Expert
Sia Bani's Avatar
Default Sounds like I'm screwed...anyone else have any insight?
I can't go the 80 route from the southbay, that's just too long, esp on a fri night with traffic through...
considering on bailing on the trip at this point.
Old 02-03-2009, 12:55 PM
AudiWorld Expert
Sia Bani's Avatar
Default Ahh...found a solution.
<a href="http://www.tpiwwp.com/v2/show.php/609_23200915700PM.png.html" target="_blank"><img src="http://www.tpiwwp.com/v2/out.php/i609_23200915700PM.png" alt="Free Image Hosting At site" /></a>
Better than going all the way up to 80, then south tahoe thru in fri night traffic. Still not other choice to cut through, but this is a doable. This would be the route to kirkwood from teh southbay
there are 3 passes, sonora 108, sr-120 ,and 4 to cut through, all of wihch are closed in the winter.
this will work
Old 02-03-2009, 01:54 PM
Member
Audi-Sav's Avatar
Default That's the way I came back from last time in Death Valley. The pass out of Markleeville
is often closed which forces you back to Tahoe and down from there.
It's a pretty drive from Marlkeeville and over the pass.
Old 02-03-2009, 02:06 PM
AudiWorld Expert
Sia Bani's Avatar
Default Hmm...actually the map i linked you to, excludes markleeville. Now trying to see if it's open
so I could potentially cut thru.
Seems like part of that route is closed, making it undoable
IS CLOSED FROM THE JCT OF US 395 (MONO CO) TO THE JCT OF SR 4
/MONITOR PASS/ (ALPINE CO) - FOR THE WINTER - MOTORISTS ARE ADVISED TO USE AN
ALTERNATE ROUTE
Old 02-03-2009, 05:14 PM
Member
Audi-Sav's Avatar
Default Looks like it's time to cowboy up and take the long way.
What's it cost to fly there? I know they've enlarged their airport in the last couple years.
Old 02-03-2009, 09:25 PM
AudiWorld Expert
Sia Bani's Avatar
Default Pci above is the route i'm taking, and only 12 miles longer than going thru markleeville
already set on doing the 340 miles vs the 260 :/, but it'll be worth it, at least for the drive back on 395.
Flights suck from here. There's a flight now from LA, so i'd have to fly to LA to cut over.
Quick Reply: Mammoth skier/boarder BT: Best driving route from up here?
