Pls help newbie to diagnose VAG (ck engine code)
Hi all,
Special thanks to Andrew (AJG) for helping with VAG..
Please be so kind to help me to understand what I need for my car (what is wrong, and how to fix it) 1998 2.8Q 98.5k miles. Thanks in advance.
Here is what VAG reading is:
VAG-COM Version: Release 303.1
Chassis Type: 8D - B5 Audi A4
Scan: 01,02,03,08,15,17,25,35,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D01
Coding: 06201
Shop #: WSC 06335
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-00 - -
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0101
Coding: 06201
Shop #: WSC 06335
4 Faults Found:
P0332 - 35-00 - -
P0411 - 35-00 - -
AudiWorld Uber User
Check your relays
carl viking
40
07-12-2024 02:45 PM
giuseppepat
09-02-2015 02:47 AM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
Touge.ca
Canadian Discussion
09-02-2015 01:28 AM
