B5 S4 Piggie Pipes Install?
Did some searching on the forum, seems like a time consuming install, evolution was trying to charge me around $700 for install on downpipes and full catback...I decided to go with piggie pipes, would you guys recommend taking it somewhere to be put in, or is it doable with out a lift? any special tools? I would also consider kicking someone beer/weed/money to help me do it, let me know!
to finish up the install!
Passenger side was a little over an 2hrs, then came the drivers side, they could not get the top bolt off the turbo! It took them several hours to get it all back in one piece.
I was there watching threw out the day, and was SO happy that I paid to get it done! It will NOT be fun doing it with jack stands in the drive way.
I paid $550 for the install.
I've done it faster but all depends on how fussy the car is. A competent shop should not take longer then that. A lift sure is nice but also not required. Some of the DP bolts can be tricky to get to, the trick is to get some short 17mm wrench and removing the driveshafts gives much better access to the bolts. With the ASP DP's you have to remove all the heat shielding to pull them out. For less then 3" you don't need too.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
Cmmartin23
26
08-23-2016 04:44 PM
S4intheOC
09-08-2015 12:12 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
