Dyno results HP 247.5 @ 5750RPM TQ316 @2750 RPM
#11
at about 4k rpm my turbos start loosing boost, they continue to loose boost until redline, making me not get all the hp that i need when my engine gets the most hp output. Is there a way to fix this with a boost controller? I have contacted neuspeed, and they tell me that they do this for turbo life reasons...
#12
You may notice that the stock K04's have a little more lag, but continue pulling longer in the RPM band because of increased efficiency. If you try and overboost your K03's to get more top end power, they simply cannot take it and will result in blown turbos or reduced lifespan.
Most chips and tuners will taper boost down to near 12psi at redline, this is to increse the longevity of the turbos. Once you increase the turbo size, you can run higher boost at redline. With stock K04's I was holding consistent 20psi all the way through. Hope this helps.
#14
-they don't want to kill your stock turbos (or not as fast)
-if you ran constant boost (like 1.2bar) to redline, by redline you'd just be blowing extremely hot air into your engine...and you're not going to be making power doing that.
-like kyle said, the K03's can only push so much air, and at redline they just aren't upto snuff (on a chipped car)
kreativecid
Q5/SQ5 MKI (8R) Discussion
16
10-04-2021 12:30 PM
bballfreak
9
04-14-2019 06:59 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
lmariorod
10-26-2017 11:39 AM
ECS Tuning-Audi
02-04-2016 08:36 AM
