4.11 rear gears available?
a S4 and RS2 will work.
a Sixspeed S4 requires alot of parts including the transmounts and front subframe, rear diff and the driveshaft.
A RS2 gearbox and reardiff will work almost as a straight fit, using the OEM driveshaft and subframe.
The 4kq and 5kq both use 4.11 finals. Depending on the rear end in the A4, may be able to use a rear gear set from a B3 (017 rear diff, 4.11:1 final).
Hey Jeff, long time no see! There are a few V8 projects going on, including a urq...check out motorgeek.com
Anyway, which rear end is in the A4? There should be a compatable ring/pinion set from an older car.
<ul><li><a href="http://www.car-videos.com/tools/speedrpm.asp?Car=Select&Num1=205&Num2=55&a mp;Num3=16&AxleRatio=4.111&Ratio1=3.5& Ratio2=1.889&Ratio3=1.231&Ratio4=.967& Ratio5=.806&Ratio6=.684&Ratio7=&Redlin e
rakta *chchchanges
12-24-2008 06:13 PM
Damiano
06-08-2007 10:03 AM
