A4 1.8t B6 performance mods
Im new to this board so not too sure what to even search for.
I have an 04 A4 1.8t AT.
Im looking for an air intake kit but there doesnt seem to be many available. Any suggestions? Carbonio makes a really nice one, EVO has one too, anything else?
Also ive really been thinking of modding the ECU. I hear good things about GIAC. Is this the best available? What else can compare?
Thanks!
Thanks!
If I was you I would do the following in this order:
Exhaust:
http://www.evoms.com/a%20a4%2018t%2002%20exhaust.htm
Intake:
http://www.evoms.com/a4%2018t%2002%20intake.htm
Diverter Valve:
http://www.tjmmotorsport.com/store/product.php?productid=16151&cat=258&page=1
Chip:
http://www.evoms.com/a%20a4%2002%2018t%20comp.htm
Exhaust:
Intake:
Diverter Valve:
Chip:
no worries there.
Exhaust is very simple, so is the DV. C/O's can be done without too much problem, spring/shock combo are a little different. Only cause you need a spring compressor to install the springs correctly.
this is the biggest bang for the buck. my bpv blew right after i chipped. an exaust won't give you more than 10hp. don't do an intake unless you go to a bigger turbo, it will have little effect with a KO3 or KO4.
You can do a cheap 710 valve, from the TT. It does well, but it doesnt have the quality like Forge, Dahlback, or hyperboost. I would get one of those 3. Cant go wrong.
