Performance and Tuning Discussion forum for various performance tuning techniques and questions
Adjustable Centre Differential (increasing ratio of torque to back wheels)
Old 01-13-2005, 04:47 PM
New Member
boomtownmouse's Avatar
Default Adjustable Centre Differential (increasing ratio of torque to back wheels)
Hey guys
Has anyone heard of anyone, or have any idea how you would go about adapting the Torsen diff system to increase the ratio of torque send to the back wheels.
The reason is that sway bar + playing with tyres / tyre pressure doesnt reduce understeer for me sufficiently. Im looking for the ability to powerslide around corners Evo style.
It would have to done by increasing the torque driven to the rear wheels and be solid enough to work with approximately 350 horsepower at the flywheel.
Thanks
Old 01-14-2005, 08:24 AM
JAFO's Avatar
Default this may be of interest....edit
close as i can link to hi bias torsen link.<ul><li><a href="http://www.stasisengineering.com/technology.shtml">http://www.stasisengineering.com/technology.shtml</a</li></ul>
Old 01-14-2005, 01:47 PM
Elder Member
LaR H 88's Avatar
Default well are you talking about power-on oversteer or transition oversteer?
it's really easy to kick the tail out by jerking the wheel back and forth, as you would in an autocross during quick transitions. however, he's talking about actually being in a corner, stomping on the gas, and having the tail come out. My car, with s4 coilovers and a NS rear bar set to stiff, will oversteer when pushed, but will understeer a bit under power. However, when i test drove the evo...i was absolutely amazed. when i got on the gas, instead of simply tracking out like my car would do, it rotated and gave me some oversteer. the car is amazing...i'm a believer. while the a4 may be able to get some oversteer during transitions, i haven't been able to create it by giving the car more gas like i could in the evo.
Old 01-14-2005, 07:05 PM
New Member
Default Re: this may be of interest....edit
Lar hit the nail on the head - I would like to achieve power on oversteer.
On a hairpin brake early and then go hard on the gas just before hitting the apex breaking the back end slightly loose and drifting the backend through the apex while the fronts stay on target and then pulling the back end back in on exit.
Thanks for the link tgjl - thats exactly the sort of thing I am looking for.
Old 01-15-2005, 12:19 PM
Junior Member
Jamez's Avatar
Default differensial lock on the rear end allows for powerslides...
I have a RS2 rear diff, with vacum controlled diff locking...
But you have to drive agressively and hard...
Drive nice, and the locked up rearwheels will steer the car straight ahead!
Old 01-16-2005, 03:33 AM
VerrÜckt's Avatar
Default What suspension are you running? I can get all sorts of oversteer with my Stasis
<center><img src="http://www.nogaroblue.com/signatures/s4jeep.gif"></center><p>and Neuspeed swaybar on hard.
Old 01-16-2005, 05:30 PM
bhvrdr's Avatar
Default Jet Jockey has a B6 A4 with the Stasis 4 to 1 Torsen mod...
allowing for up to 80/20 power distribution. Look him up. He seemed quite happy with the results. cheers! Mike
Parsec
Q5/SQ5 MKI (8R) Discussion
12-03-2012 02:04 AM
jettatoS4 (Chad)
12
12-10-2008 09:43 AM
Marin S4
20
05-09-2005 06:29 PM
DashingMax
11
12-11-2004 09:55 AM
trying to enlighten
03-02-1999 09:29 AM
Quick Reply: Adjustable Centre Differential (increasing ratio of torque to back wheels)
