Air/Fuel Ratio Gauge
<center><img src="http://i117.photobucket.com/albums/o51/richard_liberto/01-17-07_1539-1.jpg"></center><p>I wanted to install an Air/Fuel Guage. Not sure what Pin to tap into, if anybody can help or point me to an FAQ/Guide for these installs i would appreciate it greatly. Thanks.
U dont need 2 tap into ECU. Wide band will b standalone - just add a bung, and a wide band sensor
and mount the guage. Innovate has a setup you can do a wide band guage and it steps down to narrow band for ECU input. This is what I run, but my ECU accepts the wide band signal. This is a good setup and you will only need 1 sensor and can have both the narrow band for Motronic input and a wide band readout for tuning.
Rod
Rod
^^^^^Good information...
I had been told that I was going to have put a second bung on the test pipe. Are there instructions online that I can check out before I pull the trigger on the Innovate setup?
SD2IN2RBOS4
09-19-2005 07:46 AM
