Already STFA, and found conflicting info....Which Bosch generic 02 sensor can be spliced in?
97 1.8T, non DBW. Needs a front 02 sensor.
Rumor has it a standard 4 wire bosch sesnor works fine if you solder in the OEM connector, but there are a few models posted in the archives. Who here has done it, was it successful, and can you give me the part #?
Worst case I'll buck up for a stock one, but, can't hurt to ask.
Thanks!
Thanks!
P/N: 06A 906 262 Q
They are $25 ea. as opposed to $150 ea. for the S4 sensors. Might work for the A4 as well.
FYI, a tech I spoke to told me that Bosch said (in one of their training seminars) to only crimp the O2S wires not solder them.
Depending on the length of the wire needed, you might just be able to repin the Audi connector with the pins from the VW connector and forgo any crimping or soldering.
-Dave Pramanik
-Dave Pramanik
In the S4, the one I listed can be used in both the pre-cat and post-cat locations. Dunno if the same holds true for the A4s, but I would think that it would.
-Dave
-Dave
or it will corrode.
They make crimp connectors that have heat shrink tubing around them, use something like that, or put some liquid electrical tape on them.
airbil
07-17-2006 11:16 PM
daves4
9
04-28-2004 05:30 PM
repeater
02-13-2004 01:53 AM
LaserK04
11-06-2003 06:25 AM
