Anybody know the login code for the VAG-COM to recode the soft code of a ECU??
Details:
2000 A4 1.8T
original ecu soft code = 07201
new ecu soft code = 07252
I want to change the soft code on the new ecu to the soft code of the new ecu, but I don't know the login code.
Please help,
2000 A4 1.8T
Please help,
Well that didn't work :\
I borrowed a laptop from a friend that had registered VAG-COM beta 0.78 installed. The soft code still won't change. Her is more info:
MY 2000 A4 18.TQ 5-speed
New MTM ECU = 4B0-906-018-Q soft code 07252 (ATW Auto)
Old ECU = 4B0-906-018-P soft code 07201 (ATW)
I want to change the soft code because I get DTC: 18034 - Powertrain Data Bus: Missing Message from Trans. Contr.
Anybody got a suggestion???
Thanks,
Thanks,
Well it is it looks like I can't...
this is what I got from Uwe Ross, the maker of the VAG-COM:
"You can be almost 100% certain that if this ECU doesn't accept coding for a manual transmission, then it won't work with manual. Automatic and Manual ECU's were often interchangeable (with a coding change) on M5.9 (pre drive-by-wire) cars, but on the ME7 (drive-by-wire) cars, they often are not. I don't know whether there is a physical difference between the ECUs or whether it's just a matter of different firmware in them."
Speedwagon1.8T
08-04-2003 07:04 PM
S4NoRice
01-26-2003 06:47 PM
m4rcus?
09-14-2002 12:58 PM
mfjp
06-15-2001 06:45 AM
donp
06-11-2001 07:36 PM
