Anyone dyno a Stage III and/or III+ car?
<center><img src="http://pictureposter.audiworld.com/212/dyno_apr_stage_3wheel.jpg"></center><p>Carace posted this a while ago. I'm not sure exactly what he has but I know he had Schriek cams with his stage 3 when he did the test.
That dyno lists actual output...
If it was a cold day, corrected may be a little lower.
I just noticed that this was at altitude, so corrected may be higher??
If this is with and without cams, they made a nice diff on the top-end...
FB
FB
Bear in mind that altitude correction for a turbo, especially the Audi which senses mass air flow and adjusts boost to compensate, is a LOT less than correction for an NA engine.
is probably somwewhere between 6 and 12 percent. The numbers on that dyno chart have no corrections for anything factored in(temp,alt,hum etc.) I would love to do a dyno closer to sea level to see just what would happen. I know, different dyno, different day but the differences should be apparent. I know when I had my K04 kit and I went to Scottsdale, AZ the car felt so much stronger so there is some correction involved. That dyno was with the Schricks.
Wow that is quite a feat if you plan to make the car completely streetable. If it's for the track then it wouldn't be a problem. I remember when I took my Integra to DPR for headwork. I came up with about 155 to the wheels, not too bad for an LS. They had 2 poster cars one LS which put out 218hp to the wheels but the car was ONLY for the track, it was thier race car. The other was a GS-R which put out about 180hp to the wheels and this was with complete engine work, they did everything possible to the engine. the car was very streetable with a solid idle. This was about 2 years ago and I haven't been keeping up with Integra technolgy since. I do know that DPR went under about a year ago. Keep me posted on your results, good luck.
