Anyone use the "narrowband simulator" function of their wideband 02 setup?
I hate to obstruct the exhaust flow any more necessary by sticking a _third_ 02 sensor into it, so I'm considering using swapping the pre-cat 02 sensor for a wideband version and then feeding the narrowband simulator output from the controller to the ECU.
The controller manufacturer (Tech Edge -- www.techedge.com) seems cautious about recommending this and I'm curious if anyone else has done this and if so, what problems (if any) were encountered.
Thanks!
Thanks!
So you wouldn't want to install it where the pre cat o2 is at. I had mine there and when I had a misfire it always looked like I was running lean when in fact it was running rich.
I would think better b4 cats on a modified vehicle. I dont have any idea what to do on a stock setup xcept modify it:-)
They just told me that its best to put them a little further down stream because if your getting misfire and have the 02 too far up stream then you end up with readings that look very lean instead of rich readings further down stream.
BSK
01-31-2012 06:08 PM
redglow1973
10-25-2005 06:46 PM
nightkrawler
06-30-2004 12:11 PM
