Performance and Tuning Discussion forum for various performance tuning techniques and questions
Compressor surge related: Does anyone back off the throttle partially on boost? eg. city driving
Old 08-04-2004, 08:24 AM
  #21
Elder Member
Audi2ptzero's Avatar
I will try to look at one soon since a friend will have his at the 1.8t challenge tomorrow.
Old 08-04-2004, 09:33 AM
  #22
QGMika's Avatar
Default The reservoir looks like this in real life
<center><img src="http://pictureposter.audiworld.com/20982/a4dlic.jpg"></center><p>
Old 08-04-2004, 11:05 AM
  #23
Elder Member
Default So its just a tank off to the side that the bpv connects too.
Maybe its their way of solving the coke bottle sound issue.
Old 08-05-2004, 05:21 AM
  #24
fusilier's Avatar
Default It must be a "buffer box"
Perhaps the small K03 turbo which we know can make pretty decent boost at 1000 rpm according to the map, could have fluctuations(spikes) in pressure which aren't desirable in the drivability of the car. I'm pretty convinced that the box serves the purpose of just increasing the volume of the intake tract. What must be filled, has to then be emptied. If you think that Audi used K27 turbos on their 2.0 liter race motors which are much larger than the K03 on the 1.8 motor, I think its pretty clear. It was probably added to smooth out the motor's initial turbo kick in. It also stands to reason that the reservoir will lessen the symptoms of a failed BPV.
IMO if you increase your intercooler to a volume that exceeds the combined volume of the stock IC and Reservoir, the stock Reservoir shouldn't be needed. Also a change to a K04 might warrant a look at a TT225 to see if it has the reservoir. The upsize in the turbo might remove Audi's perception that the reservoir needs to be there. If it does or doesn't than that might shed some light on what the threshold point is for drivability. From a pure performance stand point, I'd remove it. The intake volume between the turbo and the valves can never be too small to improve boost response and characteristics after the throttle body opens.
Old 08-09-2004, 01:00 AM
  #25
QGMika's Avatar
I think i know what my problem is, the Forge blue spring is too stiff, anyone have a green spring?
Craigito
09-09-2006 09:33 PM
bageldog
10-01-2002 09:20 AM
got_root?
08-04-2001 01:01 AM
DocWyte
04-02-2001 07:41 PM
Quick Reply: Compressor surge related: Does anyone back off the throttle partially on boost? eg. city driving
