Data logging in VAG-COM question
I see a lot of posts about data logging sensor outputs in VAG-COM.
I have an activated VAG-COM but when I click the Log button and sepcify a file, it doesn't work!
The Graph button is also grayed out...
What am I doing wrong?
the graph feature hasn't been implemeted yet, so it should be grayed out.
you might have one of the early data-logging beta's (v.79 or.80). I think the data logging in those was kinda jacked up. Try upgrading to .81 from <a href="http://www.ross-tech.com/vag-com/download/index.html">the Ross-Tech download page</a>
Also, you need to manualy make a directory called "logs" under the main VAG-Com directory. Check and see if you have that folder.
Alex (lil' is 300)
60
12-25-2004 11:58 AM
