Has anyone fabricated a custom Aluminium Air Box?
#11
Re: WOW! your car is sooooo nice! what are the advantages to the oil catch can? What
The advantages of the catch can is very minimal.. No performance gain at all. The only reason I did this is because I don't like the old setup where the oil is routed into the intake, and it then sits at the bottom of the intercooler.
The catch can is from Canton, you can find it in race catalogs.. Yes install was done by myself, very simple install though....
#12
Yep had it on then...
The catch can is just a setup so the oil does not get routed back into the intake tract. When I took out my stock intercooler there was a lot of oil at the bottom of the intercooler, so I decided on a catch can setup. The setup is rather inexpensive.. Just the catch can a couple of fittings and thats it..
The air filter pulls in, or should I say has a ram air effect from the front of the car. There is a hose that connects to the front and directs air into the box.
Sure on the next just ask I would be glad to give you a ride..
#14
Not yet... and not aluminum
I'd like to make a custom box that feeds air fro the (unused/blanked off) passenger air intakes up to a decent panel filter. I have the LLtek intake, and it is OK, but the sharp end of the tube sticking into the cone filter leave me cold. I'd rather have a large panel filter and a velocity stack.
Ideas?
Ideas?
#16
Finally found your car in the registry...
Apparently you still have the link to your registry link to the old URL (a4.org). I looked at Mark's signature and edited the URL and voila! <ul><li><a href="http://registry.audiworld.com/audi/registry/details.asp?car=1149">Dmak's registry</a></li></ul>
#19
I'd use a panel because...
It is not true that a cone will have more area.
Area is NOT the limiting factor.
I do however want ot have an intake trumpet, with a radius of trumpet >= to diameter of intake tube to get smooth entry of air into the pipe/MAF
AJN334
09-22-2005 06:29 PM
Godzilla
05-28-2001 06:03 PM
Greyhound Guy
02-16-2001 10:58 AM
swol
10-25-2000 01:05 PM
