Help with DTC's
17964 - Charge Pressure Control: Negative Deviation
35-10 - - - Intermittent
35-00 - -
This happens only if I put in a gear 3rd or higher floor it till 6500rpm to change to next gear but right at 5500 rpm boost is lost and I get into limp mode and no check engine light I have swapped out both the stock DV and the 007Forge Dv and even re lubed it et al. I see no visible boost leaks. In the process of installing a boost gauge to help figure out the problem.
All help from will be greatly appreciated.
Thanks in advance.
35-00 - -
Thanks in advance.
I got it because I put a fmic on the car. You are getting that code because the boost sensor is seeing too much boost over requested. BTW what custom chip are you running?
So what you are saying is that I am running too much boost am I correct.
Have to take it back for him to look at just cannot leave my car there for a week.
I Have Vag logs<ul><li><a href="https://forums.audiworld.com/vag/msgs/150.phtml">Vag Logs</a></li></ul>
bushido
06-25-2007 06:01 PM
zardozrdr
12-18-2002 11:49 AM
raveman7
12-11-2002 12:38 PM
