Performance and Tuning Discussion forum for various performance tuning techniques and questions
i'm running the pc16 k04 file
Old 02-01-2005, 12:27 PM
maggio's Avatar
Default i'm running the pc16 k04 file
with the redtops and a 3.0 bar fpr. it's a tad rich, but I didn't want to run an adj fpr, can I upgrade my oem n75 valve to the 'race' version or whatever to bring in a bit more boost with the extra fuel? which valve to get?
Old 02-01-2005, 02:25 PM
TomRitt (Homebrewed)'s Avatar
Default Don't think so, because the fuel pressure rises with manifold pressure
you'll have to get an adjustable fpr, i think that file runs best around 2.8bar from when I had that set-up
Old 02-02-2005, 11:06 AM
Elder Member
Audi2ptzero's Avatar
Default If you want to use the 3 bar fpr you will need to change to the RC 310cc injectors.
But it will be cheaper to just buy the adjustable fpr. Like tom said, increasing the boost will not help since the fuel pressure will also increase.
Old 02-02-2005, 04:41 PM
LaserK04's Avatar
Default Don't skimp- buy an adj FPR.......dial it in at 26-28 psi at idle. will run great.
it's hardly more than a new N75, which will do nothing for you.
Old 02-02-2005, 07:07 PM
Elder Member
Default With the car warm and with the fpr vac line removed.
Well that is the correct way of setting the fpr.
Old 02-03-2005, 05:12 AM
shouldn't the vac line be plugged to, or is it suppose to be measured while it sucking in air?
Old 02-03-2005, 08:24 AM
Elder Member
Default I never plug mine. Once you pull the vac line the fuel pressure gauge should
sit still so you can adjust the fpr.
Old 02-03-2005, 08:49 AM
Edited, I was wrong
Old 02-03-2005, 01:49 PM
LaserK04's Avatar
Yea, true, so about 35-36 psi.
Old 02-08-2005, 04:47 PM
maggio's Avatar
Default i have an adj fpr, but no gauge, is there a way to adjust it without one?
if I don't have one, where can I get a gauge? tia.
Quick Reply: i'm running the pc16 k04 file
