Magnetic pickup rpm sensor and EGT thermocouple on compressor & turbine respectively...
<img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/Turbine-Mosaic.jpg">
These pictures are from a small jet engine that uses a centrifugal compressor wheel for its compression stage and a custom axial single stage wheel for the turbine. The turbine produces about 42Lbs of thrust at 106,000 rpms. The exhaust temperature is around 1200 degree F at full throttle.
Pictures 1 & 2 show the EGT thermocouple just barely protruding into the turbine nozzle. Picture 3 shows the magnetic pickup for measuring the compressor rpms in real time. You can get the thermocouple from www.omega.com.
Roger @ CA
Performance and Tuning
12-30-2008 07:10 AM
thewatcher101
07-10-2007 02:05 PM
Greyhound Guy
01-28-2004 01:11 PM
mantic
11
06-12-2003 10:00 PM
1999, a6, audi, compressor, magnetic, pick, pickup, pickuprpm, pics, rpm, sensor, sensors, smallengine, termocoupleur, thermocouple, turbine
