New timing belt tensioner.
<center><img src="http://pictureposter.audiworld.com/671/tensioner.jpg"></center><p>At some point after the 99 model, Audi redesigned the timing belt tensioner and obsoleted the old part. The ball and socket joint you see on the old (left) one pops apart allowing the belt to skip teeth. If you have the old style, I suggest you get your belt and tensioner replaced now. Mine failed at 35K and this is not unusual.
Rich
Rich
I'm at 58K and are starting to squeal at startup.
Going to have mine changed soon.
Did you do the install yourself or did you have the dealer?
How much was the parts and labor if dealer did it, if you don't mind sharing.
Thanks,
David
Thanks,
David
Were they damagend in any way because of the timing belt and tensioner?
4k is alot too!
Do you know how hard it is to change the valve cover gasket?
I finally took the plastic engine cover off since I bought the car used and saw that the gasket needs to be replaced because oil seems to be coming out of it. Unfortunately my car is not under warranty anymore. In the process of trying to get another warranty.
4k is alot too!
Side by side:
<img src="http://a4tqms.tripod.com/audi/images/tb_new_vs_old.jpg">
Why the new style belt is longer (bigger pulley)
<img src="http://a4tqms.tripod.com/audi/images/tb_new_vs_old_2.jpg">
Both in pieces:
<img src="http://a4tqms.tripod.com/audi/images/tb_new_vs_old_3.jpg"
Both in pieces:
