Not Hitting ANY boost.
my car is not hitting any boost what so ever. oil is starting to come out of the bov which isnt a good sign. thinking rings might be gone , but any other ideas why im not hitting boost?
i unpluged the batt. and re set the ecu. nothing. car isnt in limp mode. i even doubt that vag would even work on my car now with that split second installed ha.
if there is no oil, then you can rule out the turbo(mostly, could be damage on turbine side). Then i'd start checking thinks like frequency valve ect...
what kind of car is it?
if you pull the inlet hose to the turbo, you can check there for oil. If there is alot of oil there then its coming from the crank case. Most of the time when a turbo goes it will leak oil into the exhaust side causing it to smoke during start ups.
I think his problem could be the tial wastegate which might be stuck in the open position which just happend to a friend of mine.
My son's car just had oil shooting out the BoV. Upon further inspection..he found too much oil in the engine. He overfilled it one night, misreading the dip stick. He drained out about a quart nd no more problem. I don't know if its related.. but it can't hurt to check.
amiller77
A4 (B7 Platform) Discussion
07-29-2017 07:40 PM
Sloooo4esT
Audi Original "S" Cars
02-11-2007 09:50 PM
Stefano Scalia
11-02-2006 10:04 AM
