So if i run a Greddy Profec B EBC simply as a N75 replacement...
not to run more boost, but to replace the N75 with a better part...how exactly will it be better?
Second, since boost varies based on temps, loads, etc..wouldn't i have to adjust the EBC myself? I run 18-20 psi in winter, 20-23 psi in summer...so would i just have to choose a summer and winter setting myself?
Cheers,
Sameer
Cheers,
Sameer
It has dual solenoids. Spoolup will be a tad faster more then likely. It has a balance **** to control the wastegate boost responce. A fully adjustable low boost **** as well as another high boost **** which is also adjustable.
Like in street where I dont want to run crazy boost or its hot out, maybe play with the ricers I leave on low boost, hit the high boost button, which I know what boost level I left it on and i'm ready to rock, all business. Boost is easily adjustable to wherever u want it on the fly!
you will be getting more boost later in the RPMS and the chip will control the boost in the higher RPM's. Lots of heat from running the turbo out of the efficiency range also.More boost also will mnore then likely be moving more air and the chip will not be dumping enough fuel...lean lean lean is the verdict...although I bet the car feels stronger:-)
2low4snow
09-27-2006 05:44 PM
ski ya later
05-12-2006 12:08 PM
