Is vibration in the clutch pedal only attributed to a bad throw out bearing? What can I do to fix...
I was told slave and clutch master cylinders. Had the clutch line bleed about 4 months ago. Having a hard time pin pointing a solution or fix. I am planning on having my clutch replaced in the summer, but just the other day I got the popular "stuck clutch" issue where the clutch gets stuck to the floor. I have strong vibration in the clutch and a grinding/thrashing sound when I engage the clutch. Any advice? Thinking of just changing the cylinders for the time being, then the entire clutch when it gets warmer. I had the clutch pedal getting stuck to the floor before my clutch pedal started to vibrate, which most seem to agree is because of a bad throw out bearing. Anyone have experience or can lend some advice? Kinda stuck in a rut with this. I would greatly appreciate any advice or help. Thanks.
Throw out bearing a whirrrr whirrr sound when pedal depressed.
Slave ~$55
Master ~$60
Sachs $340 kit: bearing/clutch/pressure plate
Rod @ thepartsconnection.com (CA)1-800-472-1144
or germanautoparts.com (NY) 518 899 7807
PICTURES AT: www.audiquattroparts.com (Blau)
You could have a linkage issue or air STILL in the "bled" lines. Clutch connected to your brakefluid MC too.
Cruise the Audifans.com web site too.
HTH - Scott by BOSTON no affliation.
Slave ~$55
Master ~$60
