What would the ideal A/F curve look like?
#15
knock threshold than the subbies do. The highest I see Evos go on pump gas is high 11's when running 20 psi.
#17
You are correct, the EVO has a much higher knock threshold than a Subie, and the 1.8T probably does as well. I have seen EVO's at 12:1 on pump. (Shiv tunes at 12:1 for example)
I would not put much faith in the A/F charts John shows as I believe they were done with a sniffer. The DBW chart looks to be incorrect IMO.
I am running 11.5:1 or higher now on the STi RA motor with W/I.
#18
The readings may be a bit richer than at downpipe, but its using the same type of sensor, no?
-Dave Pramanik
-Dave Pramanik
#19
whereas with the sniffer, some gas might sneal by..just a guess.
