Performance and Tuning Discussion forum for various performance tuning techniques and questions
Will the car flip out if I completely disconnect the N75 valve and run a manual boost controller?
Old 05-25-2004, 07:40 AM
escargot's Avatar
Default Will the car flip out if I completely disconnect the N75 valve and run a manual boost controller?
If it does need it, can I just leave the electronic portion plugged in and disconnect it from any boost lines? That way it'll have no impact on anything, correct?
-Mike.
Old 05-25-2004, 07:51 AM
QCRAZY's Avatar
Default Yep, just leave it plugged in but disconnect the boost lines.
Make sure you get the MBC set right so you don't *upset* the car.
Old 05-25-2004, 09:33 AM
Elder Member
Audi2ptzero's Avatar
Default 2 ways you can do it.
Remove the N75 valve from the intake and unplug the other 2 vac lines.
2. Leave the N75 valve plugged into the intake tube while removing one vac line and looping the other vac line to the side where you just removed the first vac line.
Either way will work as long as you leave the harness plugged into the N75 valve.
Old 05-25-2004, 11:03 AM
escargot's Avatar
Default Also...
In <A HREF="http://www.autospeed.com.au/cms/A_0670/article.html?popularArticle">this</A> they use a "pressure relief valve." Do I really need one? Appearently it adjusts "wastegate creep." Is that what makes the turbo spool faster by faking that you want higher boost at first, or what? I'm just planning to do only the boost controller.
Old 05-25-2004, 11:46 AM
Junior Member
ralley's Avatar
Default that seems impressive, but is it stable?
I am not sure how a manual boost controller will stnad up to that setup, or which is actually better for the car but they seem to hook up the same way.
Old 05-25-2004, 12:56 PM
auditunerb5's Avatar
Default You def want the relief valve in there....
With both valves relief and regulator it's like a peak and hold setup. You can set to peak where ever and then the relief opens and the regulator takes over to hold at your set value. With a small turbo just the regulator works fine (works like a adjustable bleed). But with a larger turbo setup the regulator kills spoolup. The valve is stable if you keep it from heating up dramatically. (keep it in the airbox)
Old 05-25-2004, 01:15 PM
Member
Devious27t's Avatar
i run my MBC around the N75 and it works fine... search and there are some diagrams on how to do it
Old 05-25-2004, 08:58 PM
escargot's Avatar
Default SO... I installed it for now without a relief valve...
<A HREF="https://forums.audiworld.com/s4s6/msgs/25405.phtml">Click to see...</A>
-Mike.
Old 05-26-2004, 05:14 AM
Audiworld Sponsor
DAP@EPL's Avatar
Default FWIW, the MBC has a bleed hole which acts as a fixed pressure regulator.
The MBC itself is the pressure relief valve.
-Dave Pramanik
Old 05-26-2004, 01:13 PM
escargot's Avatar
Ah. Thanks!
Scott515
02-07-2017 04:43 PM
Natty Boh
9
11-14-2005 01:11 PM
TTschwing
04-24-2004 06:59 PM
jae shin
04-05-2004 01:46 PM
slowslc
12-30-2000 10:39 AM
Quick Reply: Will the car flip out if I completely disconnect the N75 valve and run a manual boost controller?
