X-Post : Driveline shudder reduced dramatically - installed Driveline Stabilizer on A4
#11
DRoss: did you notice any cabin/floor vibration at any RPM/load, beyond what was present before the installation?
Innovator: I was checking out the specs for the S4/A6 product, and it states that the spacers are aluminum and the washers are stainless steel. Will that not cause a galvanic reaction and corrosion down the road? Also, since the A4 product requires different specs anyway, will the spacers for it be cut to the CORRECT length, as opposed to the ones for S4/A6 which are (according to the install FAQ) too short?
I'm VERY interested in this product... how does its effect compare with the urethane engine snub mount? Obviously, it's a lot more expensive to produce so the price to the buyer is a lot higher...
Thanks!
Gordan
Thanks!
Gordan
#12
or will there be troubles if both are installed?
I've got the snub mount, and while it has firmed some things up, it wasn't as much as I had hoped.
I am, of course, willing to test the combo. Just send me the stabilizer, and I'll tell you how it works out
Roger @ CA
Mid Atlantic Discussion
12
05-28-2008 10:14 PM
Black Sunshine
07-01-2003 07:39 PM
Black Sunshine
12v V6 Discussion
05-27-2003 01:53 PM
D.Ross
02-26-2001 11:14 PM
