FS: Flik Justice 18x8 et33 (silver) w/ Toyo Proxes T1R's...
A stage 3 build is forcing the sale of four 9.99 out of 10 (one wheel has a minute blemish on the outer rim - see pic below) Flik Justice. They are mounted in 225/40 Toyo Proxes T1R's that have plenty of life left (see penny pic). I will not remove the tires and would prefer local pick up (Phila area) but may consider shipping but buyer will pay shipping costs.
Right now the rims are going for $180 a piece (but are out of stock)from <a href="http://edgeracing.com/2001/Audi/S4/wheel/2467/" target="_top">Edge Racing</a>.
The tires (new) are going for ~ $200 a piece from <a href="http://www.1010tires.com/tire.asp?tirebrand=Toyo&tiremodel=Proxes+T1R&pc=24 6010" target="_top">1010 Tires</a>.
I also <a href="https://forums.audiworld.com/s4/msgs/2605245.phtml" target="_top">swapped </a> out the center caps with OEM Audi Caps.
So new for this set up would be around $1500 + the center caps.
Make me a reasonable offer.
<a href="http://s159.photobucket.com/albums/t137/z01brk/?action=view¤t=P2020583.jpg" target="_blank"><img src="http://i159.photobucket.com/albums/t137/z01brk/P2020583.jpg" border="0" alt="Photobucket"></a>
<a href="http://s159.photobucket.com/albums/t137/z01brk/?action=view¤t=P2020585.jpg" target="_blank"><img src="http://i159.photobucket.com/albums/t137/z01brk/P2020585.jpg" border="0" alt="Photobucket"></a>
<a href="http://s159.photobucket.com/albums/t137/z01brk/?action=view¤t=P2020586.jpg" target="_blank"><img src="http://i159.photobucket.com/albums/t137/z01brk/P2020586.jpg" border="0" alt="Photobucket"></a>
<a href="http://s159.photobucket.com/albums/t137/z01brk/?action=view¤t=P2020587.jpg" target="_blank"><img src="http://i159.photobucket.com/albums/t137/z01brk/P2020587.jpg" border="0" alt="Photobucket"></a>
<a href="http://s159.photobucket.com/albums/t137/z01brk/?action=view¤t=P2020588.jpg" target="_blank"><img src="http://i159.photobucket.com/albums/t137/z01brk/P2020588.jpg" border="0" alt="Photobucket"></a>
<a href="http://s159.photobucket.com/albums/t137/z01brk/?action=view¤t=P2020589.jpg" target="_blank"><img src="http://i159.photobucket.com/albums/t137/z01brk/P2020589.jpg" border="0" alt="Photobucket"></a>
it'll usually eat away at those spots. Spray on, agitate with brush or sponge, let it sit for 15 minutes, then rinse. If you continue with the weekly washings, it should eventually erode those spots. P21S is probably the most friendly wheel cleaner you can find. You can let it sit on the wheel all night if you like. There is stronger stuff, but you need to be careful.
The easier way once you get them clean, is to wax the wheels (use a synthetic sealant as it holds up to heat better), and just use soap and water once a week. Brake dust should wipe right off. Every three months use a wheel cleaner and re-wax.
